Need advice utilizing 2T1's routing traffic
rob.mcdaniel
I have a Cisco 2600 series with 2 T1's connected to WAN cards. There are three physical sites connected to this router. I would like all traffic from 2 of the sites to be routed through one of the T1's back to my Central Office and all traffic from the remaining site to go through the other T1 back to the Central Office. Each site has it's own subnet. I would like all traffic from the 10.24.X.X subnet to go to one T1, and all traffic from the 10.28.X.X and 10.101.X.X subnets to go to the other T1. I'm not real clear on routing the traffic when it comes from a specific subnet. Any help would be appreciated.
thisisshanky
Level 11
Level 11
Use routemaps (policy routing)
To understand more abt policy routing Check these links
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
http://www.cisco.com/warp/public/cc/pd/iosw/tech/plicy_wp.htm
http://www.cisco.com/warp/public/105/36.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for the info. I have read the info and tried but it doesn't seem to have any effect. All packets are still routed to the default 10.255.255.10. When I take out the ip route 0.0.0.0 0.0.0.0 10.255.255.10 statement, I can't get out at all. The config for this router is included. Thanks.
interface FastEthernet0/0
description 2LAN
ip address 10.24.1.1 255.255.0.0
duplex auto
speed auto
interface Serial0/0
description To Bellsouth
no ip address
encapsulation frame-relay
no ip mroute-cache
fair-queue
frame-relay lmi-type ansi
interface Serial0/0.103 point-to-point
description TO COHOST
ip address 10.255.255.9 255.255.255.252
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 5
frame-relay interface-dlci 103
interface Serial0/1
description TO COHOST Second T1
no ip address
no ip mroute-cache
interface Serial0/1.100 point-to-point
description PVC to 2nd T1
ip address 10.153.1.1 255.255.0.0
frame-relay interface-dlci 100
router eigrp 100
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 10.28.0.0 255.255.0.0 10.24.1.2
ip route 10.101.0.0 255.255.0.0 10.24.1.3
no ip http server
no ip pim bidir-enable
access-list 1 permit 10.24.0.0 0.0.255.255
access-list 2 permit 10.28.0.0 0.0.255.255
access-list 2 permit 10.101.0.0 0.0.255.255
route-map CMSSC permit 2
match ip address 2
set ip next-hop 10.255.255.10
route-map CHS permit 1
match ip address 1
set ip next-hop 10.153.1.2
end
You need to apply a route-map to an interface (the inbound interface) in order for it to do anything -- same concept as an access-list. The interface command is "ip policy route-map xxx". Packets not matching the route-map will resort to the routing table, so in your case you only need route-map CHS.
