Need an OID for a 4006 switch
Hi all,
I really need the OID that allows me to see which IP Address is connected to each port of my 4006 switch.
Thanks in advance,
Steve
1 ACCEPTED SOLUTION
Blue
Re: Need an OID for a 4006 switch
http://www.cisco.com/warp/public/477/SNMP/cam_snmp.shtml but this will only give you the MAC add. You'll have to map them to the ip add manually. UT does it automatically for you.
Blue
I actually have to write a little external application and that's why I really need the OID string.
Steve
Blue
Great doc! I'm okay now!
Thanks a lot!!
Steve
97
