Need BGP help ASAP
I am having a problem advertising one route. I have a network statement,
network 206.129.13.0, and
aggregate-address 206.129.13.0 255.255.255.0 summary-only
But when I do a show ip bgp for the route on my router I get this output:
c7206# sh ip bgp 206.129.13.0
BGP routing table entry for 206.129.0.0/16, version 1340124
Paths: (2 available, best #1, table Default-IP-Routing-Table)
Not advertised to any peer
I have 206.129.12.0 configured the same way and sh ip bgp for this route gives this result:
c7206# sh ip bgp 207.149.12.0
BGP routing table entry for 207.149.12.0/24, version 5843366
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
63.251.175.177 206.129.33.53 206.165.194.217
Local
0.0.0.0 from 0.0.0.0 (64.240.108.1)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
6347
206.129.33.53 from 206.129.33.53 (209.83.159.21)
Origin IGP, localpref 200, valid, external, atomic-aggregate, best
Community: 6347:1021 6347:2000
14744 701 6347
63.251.175.177 from 63.251.175.177 (63.251.160.132)
Origin IGP, localpref 70, valid, external
I do not see anything in route maps, access lists etc. that would stop me from advertising this route.
Thanks.
  • Other Network Infrastructure Subjects
Silver
Re: Need BGP help ASAP
Is your aggregate statement above a typo. Shouldn't it be 206.129.12.0 255.255.254.0?
See what do you get with 'show ip bgp neighbor x.x.x.x adver'.
Do you have no sync on? Do you have correct local routes to these networks?
Thanks.
Here is my set up. Do I need to specify 255.255.255.0 in the network statement like I have for the 64.240.108.0 ?
router bgp 13853
no synchronization
bgp router-id 64.240.108.1
bgp cluster-id 3481985278
network 64.240.108.0 mask 255.255.255.0
network 64.240.109.0 mask 255.255.255.0
network 199.217.73.0
network 206.129.12.0
network 206.129.32.0
network 207.138.224.0
network 207.138.233.0
network 207.149.12.0
network 207.149.13.0
network 209.102.32.0
network 209.102.33.0
aggregate-address 64.240.108.0 255.255.255.0 summary-only
aggregate-address 64.240.109.0 255.255.255.0 summary-only
aggregate-address 199.217.73.0 255.255.255.0 summary-only
aggregate-address 206.129.12.0 255.255.255.0 summary-only
aggregate-address 206.129.32.0 255.255.255.0 summary-only
aggregate-address 207.138.224.0 255.255.255.0 summary-only
aggregate-address 207.138.233.0 255.255.255.0 summary-only
aggregate-address 207.149.12.0 255.255.255.0 summary-only
aggregate-address 207.149.13.0 255.255.255.0 summary-only
aggregate-address 209.102.32.0 255.255.255.0 summary-only
aggregate-address 209.102.33.0 255.255.255.0 summary-only
Silver
The lines:
aggregate-address 64.240.108.0 255.255.255.0 summary-only ----A
aggregate-address 64.240.109.0 255.255.255.0 summary-only -----B
Should be replaced with:
aggregate-address 64.240.108.0 255.255.254.0 summary-only ----C
because C includes networks of both A and B statments. Again, check if "show ip bgp neighbor x.x.x.x advertised" is showing you something different ( routes are being propagated). The same should be done wih the rest of summarizable networks.
You should use subnet masks for networks statements. In your case above you are using them where necessary. They should correspond to your IGP/Static routes.
Regards.
Here is show ip bgp neighbor x.x.x.x . I have no issue with the 64.240.108.0 or 109. The problem is with 206.129.13.0 / 24. 206.129.12.0/24 is fine and there is no difference in their config. Could this be an issue with my provider?
7206#sh ip bgp neighbor 206.129.33.53 advertise
BGP table version is 6298658, local router ID is 64.240.108.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 64.240.108.0/24 0.0.0.0 0 32768 i
*> 64.240.109.0/24 0.0.0.0 0 32768 i
*> 199.217.73.0 0.0.0.0 0 32768 i
*> 206.129.12.0 0.0.0.0 0 32768 i
*> 206.129.32.0 0.0.0.0 0 32768 i
*> 207.138.224.0 0.0.0.0 0 32768 i
*> 207.138.233.0 0.0.0.0 0 32768 i
*> 207.149.12.0 0.0.0.0 0 32768 i
*> 209.102.32.0 0.0.0.0 0 32768 i
*> 209.102.33.0 0.0.0.0 0 32768 i
Silver
Do you have 206.129.13.0 / 24 entry in your routing table?
If you really want to advertise, this 13.0, to your neighbor (no matter what) then add this line to your config:
aggregate-address 206.129.12.0 255.255.254.0 summary
Of course, the above wont work if filters dont allow it to.
If you are suppose to be receiving this route from your provider then yes it could be their problem. Check your prefix-lists or route-maps too.
Thanks.
I fixed it by entering ip route 206.129.13.0 255.255.255.0 null0 254
thanks for all the help.
103
