Need help configure Cisco routers for private leased line
tnguyen
I have a Cisco 2611 and a 1711 routers. We're currently using the 2 routers to do frame relay (512K). I'll be switching it over to a full T1 leased line next month. I have never configure the routers for this type of connection before. Would appreciate any helps I can get to configure them. Thanks in advance to everyone.
/Tony
5 Replies 5
wgmt
are you installing wic-1dsu-t1 cards or using external CSUs?
BT
It would be with internal CSU/DSL on both routers.
Normally on point to point connections it is a dry circuit. On one of your routers, you must provide clocking. On the other end, you will take clocking from the line. You'd end up with something like this:
Router1 (provides clocking)
Interface serial 0/0
service-module t1 clock source internal
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 10.1.1.1 255.255.255.0
encapsulation ppp
Router2:
service-module t1 clock source line
ip address 10.1.1.2 255.255.255.0
encapsulation ppp
-HTH
Thank you so much. I'll give this a try and let you know. So beside this configuration, there's nothing else that I need to type? Thanks again.
/Tony
That was just an example. There may be some things you have to change:
Your DSU may be in a different slot than s0/0.
Change the IPs to what you want.
Make sure you have routing (either via static routes or dynamic routing) working ok.
-HTH
