need help configuring an 804 IDSL router
What is wrong with this config? I can ping the Ethernet interface from my PC, but not the BRI0 interface, nor the DNS IPs. The sample configs Cisco gives for IDSL are not very helpful.
! Cisco IOS router configuration file
! Automatically made by Cisco Fast Step v2.2
! Designed for Cisco C804
! June 09, 2002
! Cisco Fast Step Template
no service udp-small-servers
no service tcp-small-servers
service password-encryption
hostname Router
username Router password ******
enable secret ******
no ip source-route
isdn switch-type basic-ni
isdn leased-line BRI0 144
ip routing
ip classless
ip subnet-zero
ip name-server 66.92.159.2
ip name-server 216.231.41.2
interface ethernet 0
keepalive
no shutdown
ip address 66.93.105.225 255.255.255.224
ip route-cache
no ip proxy-arp
no ip directed-broadcast
interface bri 0
ip address 66.92.165.205 255.255.255.0
encapsulation frame-relay IETF
fair-queue 64 16 0
no arp frame-relay
frame-relay lmi-type ansi
no shutdown
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0
1 REPLY
Bronze
Re: need help configuring an 804 IDSL router
Try adding a frame-relay map to the BRI interface, pointing to the remote IP address. You may also want to change your static route, instead of pointing to the BRI, point it to the remote IP address, and then add a static route pointing the remote IP address to the BRI interface.
94
