Need help configuring static nat on 2600 IOS 11.3(2)XA1
I'm attempting to setup static NAT to help ease the process of consolidating addresses. I have followed the guidelines to the word as presented in the Cisco documentation series for my IOS, but it seems the commands simply do not exist.
I am referring to this document:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113ed_cr/dial_r/drprt11/drnat.htm#40606
I am executing the commands in Global config mode:
pericles(config)#ip nat inside source ?
list Specify access list describing local addresses
pericles(config)#ip nat inside source static ?
% Unrecognized command
Is there something I am missing? I have tried adding the inside and outside designations to the interfaces first, then trying to specify the static translations, but the command still does not appear. Seems like all I can do is configure dynamic translations, which is not what I am trying to do.
Here's what I get when I query the ip nat command:
pericles(config)#ip nat ?
inside Inside address translation
translation NAT translation entry configuration
seems odd that there aren't more commands, like pool or outside.
What am I missing here? Any help would be very appreciated.
Re: Need help configuring static nat on 2600 IOS 11.3(2)XA1
I had the same problem and found that 11.3 doesn't support NAT . I suggest you upgrade your code in order to support NAT ...
cheers,
Dave
I don't think that "full" NAT is supported in the IP release of 11.3. I believe that you need "IP Plus".
Mick.
99
