Need help configuring static nat on 2600 IOS 11.3(2)XA1
I'm attempting to setup static NAT to help ease the process of consolidating addresses. I have followed the guidelines to the word as presented in the Cisco documentation series for my IOS, but it seems the commands simply do not exist.
I am referring to this document:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113ed_cr/dial_r/drprt11/drnat.htm#40606
I am executing the commands in Global config mode:
pericles(config)#ip nat inside source ?
list Specify access list describing local addresses
pericles(config)#ip nat inside source static ?
% Unrecognized command
Is there something I am missing? I have tried adding the inside and outside designations to the interfaces first, then trying to specify the static translations, but the command still does not appear. Seems like all I can do is configure dynamic translations, which is not what I am trying to do.
Here's what I get when I query the ip nat command:
pericles(config)#ip nat ?
inside Inside address translation
translation NAT translation entry configuration
seems odd that there aren't more commands, like pool or outside.
What am I missing here? Any help would be very appreciated.
1 REPLY
Re: Need help configuring static nat on 2600 IOS 11.3(2)XA1
ip nat pool dom 200.3.89.154 200.3.89.159 netmask 255.255.255.248 type rotary
ip nat inside source list 1 pool dom overload
interface Ethernet0/0
ip address 172.21.4.1 255.255.255.128
ip nat inside
interface Loopback50
ip address 200.3.89.153 255.255.255.248
ip nat outside
interface Serial0/0.1 point-to-point
description (INTERNET) ---> M.Office
ip address 200.3.74.78 255.255.255.252
ip nat outside
frame-relay interface-dlci 151
ip route 0.0.0.0 0.0.0.0 200.3.74.77
ROUTER#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 11.3(7)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Tue 01-Dec-98 12:31 by ccai
Image text-base: 0x80008084, data-base: 0x8082C820
ROM: System Bootstrap, Version 11.3(2)XA3, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
ROUTER uptime is 8 weeks, 4 days, 1 hour, 59 minutes
System restarted by power-on at 07:05:07 UTC Mon Jan 28 2002
System image file is "flash:c2600-is-mz_113-7_T.bin", booted via flash
cisco 2610 (MPC860) processor (revision 0x202) with 16384K/4096K bytes of memory.
Processor board ID JAB023804M6 (1758503988)
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Low-speed serial(sync/async) network interface(s)
2 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
ROUTER#
ROUTER#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Serial0/0.1, Loopback50
Inside interfaces:
Ethernet0/0
Hits: 817 Misses: 113
Expired translations: 120
Dynamic mappings:
-- Inside Source
access-list 1 pool dom refcount 0
pool dom: netmask 255.255.255.248
start 200.3.89.154 end 200.3.89.159
type rotary, total addresses 6, allocated 0 (0%), misses 0
ROUTER#sh ip nat translations
Hope this help
218
