Need help deciding on router
Hi guys,
I was looking for your expertise if I may... I will be setting up a small business network next week and I am trying to decide which router to go with. I will need the following capabilities..
-- Ability to act as Cable/dsl Modem
-- VPN capability
-- support 10-15 network computers
-- Wireless (if possible)
If you guys could please point me in the direction of which Cisco router I should integrate I would much appreciate it! This is going to be a windows 2003 server environment if that also helps.
Thanks!
Re: Need help deciding on router
This is the profile that fits on a cisco 1800 series fixed configuration router:
http://www.cisco.com/en/US/products/ps5853/prod_models_comparison.html
regards,
Leo
800 series routers would also fit the bill as a lower cost solution:
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
120
