need help Dialin with 3745, failed!!!
hi my name is Bob!
i have issue with dialin on cisco 3745(NM-16AM module);
really hope you can help me...ASAP
when the client dial to router :
modem state : 'dialing/anwering'
modem state : 'incoming call'
modem state : ' waiting for carrier'
then disconnected!! reason 'NO CARRIER'!
this is the confoguration on my router 3745 :
Current configuration : 2420 bytes
version 12.2
service password-encryption
hostname "RTRKRG"
enable secret xxxx
username xxxx password xxxx
username pln password xxxx
ip subnet-zero
no ip domain lookup
async-bootp dns-server 10.201.1.4
mta receive maximum-recipients 0
interface Loopback0
ip address 10.x.x.xxx.255.255.0
interface FastEthernet0/0
ip address 10.x.x.x.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/0
ip address 20.x.x.x x.255.255.252
shutdown
clockrate 125000
no fair-queue
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/1
ip address 20.100.x.x.x.255.252
shutdown
clockrate 125000
no cdp enable
interface Serial1/0
shutdown
no cdp enable
interface Serial1/1
no ip address
shutdown
no cdp enable
interface Serial1/2
no ip address
shutdown
no cdp enable
interface Serial1/3
no ip address
shutdown
no cdp enable
interface Serial1/4
no ip address
shutdown
no cdp enable
interface Serial1/5
no ip address
shutdown
no cdp enable
interface Serial1/6
no ip address
shutdown
no cdp enable
interface Serial1/7
no ip address
shutdown
no cdp enable
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address pool dialin
no keepalive
ppp authentication chap
group-range 65 80
router rip
network 10.0.0.0
network 20.0.0.0
ip local pool dialin 10.x.x.x.50.1.31
ip classless
ip http server
dialer-list 1 protocol ip permit
no cdp run
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
password xxx
login
line 65 80
flush-at-activation
login local
modem Dialin
modem autoconfigure discovery
autocommand ppp
transport input all
autoselect ppp
flowcontrol hardware
line 129 144
flush-at-activation
line aux 0
password xxxx
login
line vty 0 4
password xxxx
login
end
please help me, to solve this issue...
  • Other Network Infrastructure Subjects
Re: need help Dialin with 3745, failed!!!
What modem lines the calls are coming in on ? If its line 129 144, obviously calls will not connect as these lines do not have the tty config like the lines 65 80 do. If you could include modem/modem csm/ppp debugs, that would be helpful.
~Zulfi
~Zulfi
83
