NEED HELP FAST...aggregating multiple E1 interfaces on 1760 access router
hey all,
i am trying to develop a solution which envolves bundling 2 E1 interfaces so that they become 1 logical 4Mbps high speed link. i have tried Multilayer Multilink PPP but it seems that this router does not axcept the commands. i also tried portchannel (which doesn't apply since E1 isn't ethernet but thought i'd try it anyway). i'm running IOS ver 12.2(8)YJ, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1). the router is a cisco 1760 with 2 WIC E1 cards and 1 VIC card.
thanks for your help
Silver
Re: NEED HELP FAST...aggregating multiple E1 interfaces on 1760
MPPP should work. You can also try using int multilink
What is your config?
Thanks.
no config as of yet. with MPPP, the entire physical T1/E1 link is subdevided into logical links witch can be used for this purpose. but what i have is 2 E1 interfaces and i want to join them into one logical 4Mbps (2Mbps +2Mbps) pipe.
if you beleive that this can be done with MPPP, please explain how
thanks...
Silver
I would simply config ppp encapsulation with ppp multilink command.
This link may help you as well: http://cisco.com/en/US/tech/tk713/tk628/technologies_configuration_example09186a00800a5efa.shtml
well i got it working using PPP combined with link bundelling. i now have a total of 4Mbps:
interface Multilink1
ip address IP_ADD NET_MASK
ppp multilink
multilink-group 1
now my manager wants me to cascade this router to another 1760 for a total of 8Mbps. multichassis MLPPP didn't do the trick....any ideas?
PS. i will post this Q as a new thread.
109
