Need help on CAR
I have a router cisco 2600 to connect to internet.
Because I only have 128 Kbps for internet access so I want to controll bandwidth for users on the LAN for example, user1 - 64 kbps, user 2 -24 kbps ...). Following is summary about my router configuration:
ip cef
interface Ethernet0/0
ip address 192.168.10.1 255.255.255.0
rate-limit input access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 11 24000 8000 8000 conform-action transmit exceed-action drop
access-list 11 permit 192.168.10.11
access-list 11 permit 192.168.10.12
access-list 12 permit 192.168.10.111
Butwhen I do the test, users can download above the speed I have setup for them !!!
Please help me to fix this problem !!! If CAR can not resolve this problem, pls give me another solution !!!
Re: Need help on CAR
Hello Mat,
the problem is most likely due to the fact that you are using a standard-access-list 1-99 i.e this checks the 'source' ip address, therefore when transmitting out of the e0/0 interface, the source addresses specified in the access-list 12 would not satisfy the car statement, as the source address would not match.
Instead, configure extended access-lists to match your traffic
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt2/1rip.htm#xtocid217152
i.e for traffic to and from host 192.168.10.111 :
ip cef
rate-limit input access-group 100 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 101 64000 8000 8000 conform-action transmit exceed-action drop
access-list 100 permit ip host 192.168.10.111 any
access-list 101 permit ip any host 192.168.10.111
Then check traffic to-from this host.
Please let us know results.
rgds
stvee
It have fixed my problem.
Thanks a lot
111
