Community Member
Need help on Cisco 7513
We have cisco 7513 with 2*RSP4(64 DRAM 16 FLASH), VIP2-15(1 FastEthernet, 8 port Serial EIA/TIA-232), VIP2-40(1 FastEthernet, 8 port Serial V.35)
IOS rsp-jsv-mz.112-7.P
When I change (update) IOS from ver.11.2(7)P to ver.12.1(6) or 12.0(3)T VIP2-15 not initialized.
in than can be reason?
Re: Need help on Cisco 7513
I ran the above through the HW/SW matrix and it looks like 12.1(6) should be ok, but 12.0(3)T isn't okay. The matching 12.0T image for the hardware you listed is 12.0(7)T at a minimum. 12.2(1) or higher mainline release is also ok according to the matrix.
What errors are you getting on boot? Maybe if you post a capture we can be of more help.
Regards, Erick
Community Member
I have similar config on my 7513, and ran the HW/SW matrix for the first time, after i saw your note. I found 12.0(7)T at a minimum, Does it mean that I can use 12.0(19) IOS. I like to use 12.0(19) because its a "GD". Thanks. vic.
Community Member
I would suggest using 12.0(19)S.
134
