need help to config bri
okenobi
i have 1 cisco 1603 and 1 cisco 2621..they both have eth,serial and bri interfaces
the routers are connected with a leased line and i need to configure backup isdn
the 1603 will use one line to connect to the 2621 and the 2621 uses 1 of his channels to connect to isp..
i dont have a problem with the 1603,it`s simple.
how do i make the 2621 to wait for call in 1 channel and be connected with the other channel to isp
thanks
mazhar71
Define 2 dialer interface on 2621. Dialer 1 will be used for coming call from 1601. Dialer2 is configured to dial out. On dialer1 enter "dialer pool 1" , on dialer2 enter "dialer pool 2".
And on bri interface enter "dialer pool member 1 min 1 max 1" and "dialer pool member 2 min 1 max 1".
I think this will solve your problem
