Need Help with PPP AUX to AUX!
Hi there,
I'm trying to make this lab work, using 2 x 2611 routers, the dialing router calls and and the modem picks up at the other end, but the called router does not respond to the chap challenge, I'm able to dialing using hyper terminal for exec dialing, that's working fine...
I have turned on debug for chat, ppp authentication and ppp negotiation on both routers, but I only get an output on the calling router.
Here is the output from the calling router:
remote#
00:07:51: CHAT65: Attempting async line dialer script
00:07:51: CHAT65: Dialing using Modem script: async & System script: none
00:07:51: CHAT65: process started
00:07:51: CHAT65: Asserting DTR
00:07:51: CHAT65: Chat script async started
00:07:51: CHAT65: Sending string: AT
00:07:51: CHAT65: Expecting string: OK
00:07:51: CHAT65: Completed match for expect: OK
00:07:51: CHAT65: Sending string: ATDT\T<905889xxxx>
00:07:51: CHAT65: Expecting string: CONNECT
00:08:11: CHAT65: Completed match for expect: CONNECT
00:08:11: CHAT65: Sending string: \c
00:08:11: CHAT65: Chat script async finished, status = Success
00:08:11: As65 IPCP: Install route to 192.168.1.1
00:08:13: %LINK-3-UPDOWN: Interface Async65, changed state to up
00:08:13: As65 PPP: Treating connection as a callout
00:08:13: As65 PPP: Phase is ESTABLISHING, Active Open
00:08:13: As65 LCP: O CONFREQ [Closed] id 1 len 25
00:08:13: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:08:13: As65 LCP: AuthProto CHAP (0x0305C22305)
00:08:13: As65 LCP: MagicNumber 0x014A08D7 (0x0506014A08D7)
00:08:13: As65 LCP: PFC (0x0702)
00:08:13: As65 LCP: ACFC (0x0802)
00:08:15: As65 LCP: TIMEout: State REQsent
00:08:15: As65 LCP: O CONFREQ [REQsent] id 2 len 25
00:08:15: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:08:15: As65 LCP: AuthProto CHAP (0x0305C22305)
00:08:15: As65 LCP: MagicNumber 0x014A08D7 (0x0506014A08D7)
00:08:15: As65 LCP: PFC (0x0702)
00:08:15: As65 LCP: ACFC (0x0802)
00:08:17: As65 LCP: TIMEout: State REQsent
00:08:17: As65 LCP: O CONFREQ [REQsent] id 3 len 25
00:08:17: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:08:17: As65 LCP: AuthProto CHAP (0x0305C22305)
00:08:17: As65 LCP: MagicNumber 0x014A08D7 (0x0506014A08D7)
00:08:17: As65 LCP: PFC (0x0702)
00:08:17: As65 LCP: ACFC (0x0802)
00:08:17: As65 LCP: I CONFREQ [REQsent] id 3 len 25
00:08:17: As65 LCP: O CONFNAK [REQsent] id 3 len 10
00:08:17: As65 LCP: MagicNumber 0x014A188F (0x0506014A188F)
00:08:17: As65 LCP: I CONFNAK [REQsent] id 3 len 10
00:08:17: As65 LCP: O CONFREQ [REQsent] id 4 len 25
00:08:17: As65 LCP: MagicNumber 0x014A1898 (0x0506014A1898)
00:08:17: As65 LCP: I CONFREQ [REQsent] id 4 len 25
00:08:17: As65 LCP: O CONFNAK [REQsent] id 4 len 10
00:08:17: As65 LCP: MagicNumber 0x014A18AD (0x0506014A18AD)
00:08:17: As65 LCP: I CONFNAK [REQsent] id 4 len 10
00:08:17: As65 LCP: O CONFREQ [REQsent] id 5 len 25
00:08:17: As65 LCP: MagicNumber 0x014A18B6 (0x0506014A18B6)
00:08:17: As65 LCP: I CONFREQ [REQsent] id 5 len 25
00:08:17: As65 LCP: O CONFNAK [REQsent] id 5 len 10
00:08:17: As65 LCP: MagicNumber 0x014A18CB (0x0506014A18CB)
00:08:17: As65 LCP: I CONFNAK [REQsent] id 5 len 10
00:08:17: As65 LCP: O CONFREQ [REQsent] id 6 len 25
00:08:17: As65 LCP: MagicNumber 0x014A18D4 (0x0506014A18D4)
00:08:17: As65 LCP: I CONFREQ [REQsent] id 6 len 25
00:08:17: As65 LCP: O CONFNAK [REQsent] id 6 len 10
00:08:17: As65 LCP: MagicNumber 0x014A18E9 (0x0506014A18E9)
00:08:18: As65 LCP: I CONFNAK [REQsent] id 6 len 10
00:08:18: As65 LCP: MagicNumber 0x014A18E9 (0x0506014A18E9)
00:08:18: As65 LCP: O CONFREQ [REQsent] id 7 len 25
00:08:18: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:08:18: As65 LCP: AuthProto CHAP (0x0305C22305)
00:08:18: As65 LCP: MagicNumber 0x014A18F2 (0x0506014A18F2)
00:08:18: As65 LCP: PFC (0x0702)
00:08:18: As65 LCP: ACFC (0x0802)
00:08:18: As65 LCP: I CONFREQ [REQsent] id 7 len 25
00:08:18: As65 LCP: O CONFNAK [REQsent] id 7 len 10
00:08:18: As65 LCP: MagicNumber 0x014A1907 (0x0506014A1907)
00:08:18: As65 LCP: I CONFNAK [REQsent] id 7 len 10
00:08:18: As65 LCP: O CONFREQ [REQsent] id 8 len 25
00:08:18: As65 LCP: MagicNumber 0x014A1910 (0x0506014A1910)
00:08:18: As65 LCP: I CONFREQ [REQsent] id 8 len 25
00:08:18: As65 LCP: O CONFREJ [REQsent] id 8 len 10
00:08:18: As65 LCP: I CONFREJ [REQsent] id 8 len 10
00:08:18: As65 LCP: O CONFREQ [REQsent] id 9 len 19
00:08:18: As65 LCP: I CONFREQ [REQsent] id 9 len 19
00:08:18: As65 LCP: O CONFACK [REQsent] id 9 len 19
00:08:18: As65 LCP: I CONFACK [ACKsent] id 9 len 19
00:08:18: As65 LCP: State is Open
00:08:18: As65 PPP: Phase is AUTHENTICATING, by both
00:08:18: As65 CHAP: O CHALLENGE id 1 len 27 from "remote"
00:08:18: As65 CHAP: I CHALLENGE id 1 len 27 from "remote"
00:08:18: As65 AUTH: Started process 0 pid 2
00:08:18: As65 CHAP: Ignoring Challenge with local name
00:08:28: As65 CHAP: O CHALLENGE id 2 len 27 from "remote"
00:08:28: As65 CHAP: I CHALLENGE id 2 len 27 from "remote"
00:08:28: As65 CHAP: Ignoring Challenge with local name
00:08:38: As65 CHAP: O CHALLENGE id 3 len 27 from "remote"
00:08:38: As65 CHAP: I CHALLENGE id 3 len 27 from "remote"
00:08:38: As65 CHAP: Ignoring Challenge with local name
00:08:45: %LINK-5-CHANGED: Interface Async65, changed state to reset
00:08:45: As65 PPP: Phase is TERMINATING
00:08:45: As65 LCP: State is Closed
00:08:45: As65 PPP: Phase is DOWN
00:08:48: As65 IPCP: Remove route to 192.168.1.1
00:08:50: %LINK-3-UPDOWN: Interface Async65, changed state to down
00:08:50: As65 LCP: State is Closed
**********calling router config**********
Current configuration : 1759 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname remote
aaa new-model
aaa authentication login default local
aaa authentication login no_authen none
aaa authentication ppp default local
enable secret 5 $1$RlFW$j5TrJmWrKa3RX.EjQrkWI/
username admin password 0 vernon
username toronto password 0 cisco
ip subnet-zero
no ip finger
no ip domain-lookup
ip host modem 2065 10.1.1.2
chat-script async "" "AT" OK "ATDT\T" TIMEOUT 30 CONNECT \c
modemcap entry my_modem:MSC=&f1s0=1
interface Loopback0
ip address 10.1.1.2 255.0.0.0
interface Ethernet0/0
ip address 172.17.1.1 255.255.0.0
interface Serial0/0
no ip address
no ip mroute-cache
no fair-queue
interface Ethernet0/1
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface Async65
ip address 192.168.1.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer map ip 192.168.1.1 name toronto broadcast 905889xxxx
dialer map ip 172.16.1.0 name toronto broadcast 905889xxxx
dialer-group 1
async default routing
async mode interactive
no peer default ip address
ppp authentication chap
router rip
version 2
network 10.0.0.0
network 172.17.0.0
network 192.168.1.0
no auto-summary
ip classless
ip http server
dialer-list 1 protocol ip permit
line con 0
login authentication no_authen
transport input none
line aux 0
exec-timeout 0 0
autoselect ppp
script dialer async
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 56000
flowcontrol hardware
line vty 0 4
end
remote#
**********Called Router config**********
version 12.1
hostname toronto
aaa new-model
username remote password 0 cisco
ip subnet-zero
no ip finger
no ip domain-lookup
interface Loopback0
ip address 10.2.1.1 255.0.0.0
ip address 172.16.1.1 255.255.0.0
interface Serial0/0
no ip address
no ip mroute-cache
no fair-queue
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface Async65
encapsulation ppp
dialer in-band
dialer map ip 192.168.1.2 name remote broadcast
dialer map ip 172.16.1.0 name remote broadcast
dialer-group 1
router rip
version 2
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
no auto-summary
ip classless
ip http server
line con 0
line aux 0
exec-timeout 0 0
autoselect ppp
script dialer async
modem InOut
transport input all
stopbits 1
speed 56000
line vty 0 4
end
toronto#
Re: Need Help with PPP AUX to AUX!
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Bronze
The debug on the calling router makes it look like things are looped, since the Magic Number, the packet IDs, and the name used by the CHAP process are all the same (indicating we are receiving the packet that we just sent out).
There isn't really much in the config that could cause this (and the config looks fine anyway), so I would suggest you confirm the numbers being dialed and the modem configs. Debug modem might be of interest to you, too. Finally, you could try to reverse telnet from one of the routers to the aux port, manually dial 905889xxxx, and see if you get the login prompt for the remote.
The line is fine, It was the modem adapter some one had changed the pin out on me...
Many thanks
92
