Community Member
Need HELP! WS-X4232-L3 Routing module in 4006 switch
Hi, I need help with this. I have a WS-X4432-L3 module in a Cisco 4006 switch.
Here is the situation. Routers from 3 other locations will be using the 10.50.x.x network to come into the main office. The network in the main office is 10.30.x.x. There are other routers in the main office which do HSRP, etc. That's where the traffic would be coming in. I would like to configure the routing module which is in the main switch (4006) to receive all the 10.50.x.x traffic and send it out through the 10.30.x.x network. I need some information to get started including what cables need to be plugged in and what interfaces need to configured. We do use EIGRP within the frame network from other sites to the main office.
Silver
Re: Need HELP! WS-X4232-L3 Routing module in 4006 switch
Here are some real useful documents in configuring and explaining router modules on cat 4000 series switches. I think these documents will guide you through.
http://www.cisco.com/warp/public/473/28.html
http://www.cisco.com/warp/public/473/141.html
Community Member
The WS-X4232-L3 is tricky, please read this document:
http://www.cisco.com/warp/customer/473/28.html
That should get you started. After that, let us know if there are any clarification points.
216
