Webcast-Catalyst9k
Need Help
1) How to send 7204 router logging messages to AUX port
2) What is the pin config details for Aux port (RJ45) to Terminal server.
1 REPLY
Silver
Re: Need Help
By default, system logging messages are sent to console and Telnet sessions based on the default logging facility and severity values. If desired, you can disable logging to the console or logging to a given Telnet session.To configure Cisco Devices for Syslog messages, use the following commands
Router(config)# logging on(To make sure logging is enabled)
To specify that the terminal server should receive the router syslog messages, use the logging command, where ip_address is the IP address of the server.
2.The following is the pin details for the cable connecting Aux port to Terminal server.
Pin Description
1 Receive Data + (RxD+)
2 RxD-
3 Transmit Data + (TxD+)
6 TxD-
82
