Need HELP!
I'm trying to transfer some files through a messaging client like msn messenger. It keeps failing saying to contact the administrator. We have private addressing here so I know that is a problem. I have configured the
cisco router to map a static outside IP to my inside IP, but that didn't help either. We are running NAT on the router. I am assuming some ports need to be opened.. Also, I would like to make online gaming available to some people as well and I believe this won't work behind NAT without changes either. Any help? THANKS!
Re: Need HELP!
without describing your network topology and "copy & past" your router
config, nobody can help you.
When you do so, the community can get an idea what possibly is wrong.
regards Ulrich Marzoli
www.netaid.de
Re: Need HELP!
Here is the router config.
ip subnet-zero
ip name-server 10.2.1.21
appletalk routing
ipx routing 0030.8076.3740
process-max-time 200
interface FastEthernet0/0
description connected to 10.2.1.0
ip address 10.2.1.1 255.255.255.0
no ip directed-broadcast
ip nat inside
speed 100
full-duplex
appletalk cable-range 220-230 220.226
appletalk zone KHS
ipx network 2BAD222 encapsulation SAP
no mop enabled
interface Serial0/0
description connected to Internet
ip address xx.xxx.xxx.xxx 255.255.255.252
ip nat outside
encapsulation ppp
interface FastEthernet0/1
description connected to FIBER WAN
ip address 10.20.1.1 255.255.255.0
ip helper-address 10.2.1.21
ip nat inside
speed 100
full-duplex
appletalk cable-range 500-500 500.35
appletalk zone KHS
ipx network BAD333 encapsulation SAP
no mop enabled
interface Ethernet1/0
description connected to 10.1.1.0
ip address 10.1.1.1 255.255.255.0
ip nat inside
appletalk cable-range 200-210 205.120
appletalk zone KHS
ipx network 1BAD111 encapsulation SAP
no mop enabled
router rip
version 2
passive-interface Serial0/0
network 10.0.0.0
no auto-summary
ip nat pool TONGASS-natpool-1 xx.xxx.xxx.xx xx.xxx.xxx.xxx netmask 255.255.255.0
ip nat pool TONGASS-natpool-2 xx.xxx.xxx.x xx.xxx.xxx.xxx netmask 255.255.255.0
ip nat inside source list 1 pool TONGASS-natpool-1 overload
ip nat inside source list 2 pool TONGASS-natpool-2 overload
ip nat inside source static 10.2.1.252 xx.xxx.xxx.xxx
ip nat inside source static 10.2.1.24 xx.xxx.xxx.xx
ip nat inside source static 10.2.1.23 xx.xxx.xxx.xx
ip nat inside source static 10.2.1.22 xx.xxx.xxx.xx
ip nat inside source static 10.2.1.21 xx.xxx.xxx.xx
ip classless
ip forward-protocol udp 135
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
access-list 1 permit 10.2.1.0 0.0.0.255
access-list 1 permit 10.20.1.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.18.1.0 0.0.0.255
access-list 1 permit 10.14.1.0 0.0.0.255
access-list 1 permit 10.12.1.0 0.0.0.255
access-list 1 permit 10.10.1.0 0.0.0.255
access-list 1 permit 10.8.1.0 0.0.0.255
access-list 1 permit 10.6.1.0 0.0.0.255
access-list 1 permit 10.4.1.0 0.0.0.255
access-list 1 permit 10.16.1.0 0.0.0.255
snmp-server engineID local 000000090200003080763740
snmp-server community public RO
snmp-server location KHS, BACK-BONE CLOSET
snmp-server contact ADMIN,907.225.8592,admin@kgbsd.org
line con 0
exec-timeout 0 0
password xxxxx
login
transport input none
line aux 0
line vty 0 4
password xxxxx
login
no scheduler allocate
end
87
