Need info on SnapShot dialing
hi
i have a customer whos having leased line and isdn as his backup.he needs to check the status of the ISDN without any manual intercetptions regularly once in a week.while testing the same he doesnt want to make his LL down..
i planned to use snapshot dialing on this situation,b4 using the same i need to know will it work since i hvent used the same earlier.
I have palnned the following config to check the isdn on every wednesday at 1:00 to 1:10...
time-range DIALBK
periodic Wednesday 1:00 to 1:10
since i hvent implemented or configured the same earlier will this work on this type of situation??has anybody configured the same earlier ??
pls do advice on this ....
regds
prem
Re: Need info on SnapShot dialing
You need to assign that time-range with the access-list to define the interesting traffic. After that it should work fine.
Here is the link for that
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_r/ffrprt3/frf012.htm#1026086
For configuring the snapshot routing with dialer profiles
http://www.cisco.com/warp/public/793/access_dial/ddr_9347.html
hi patel
thks for the link ...let me try the same and get back ....
regd
prem
Community Member
Hello Prem,
Can u post ur DIALBK script (or dialer profile) u r using ?
Vijayendra K. S.
98
