Community Member
Need solution - URGENT
A router 3600 assure the connection between two backup sites by an isdn connection. My problem is; my serial connection is up but when i try to test the backup line (dial-up connection) it gaves this answer: "ISDN BR1/1 received a call with a bad bearer cap from (phone number)on B1".
Whatcoul be the cause of this?
1 REPLY
Community Member
Re: Need solution - URGENT
Hi ..
It seems that the router is trying to connect using A data over voice call. where as your router is expecting a data call.I guess you will have to check with your ISDN provider and get your line checked.
Also do debug
Plz go through this link
http://www.cisco.com/warp/public/793/access_dial/8.html
Sorry for any mistakes.
129
