Need to configure 7507x2 with 6506 Multi-vlan
Present setup the second 7507 is OFF
Need to configure 7507 Wan port's which is Ethernet and connected to 7200 router and 7200 is connected to T1 to pivate remote offices.
3 ethernet ports are used on 7507 for LAN and connected to 6506 serving 3 differnet vlan
Need advice
I need to Configure the second 7507as redented router
1 REPLY
Re: Need to configure 7507x2 with 6506 Multi-vlan
Your topology is not very clear from the description. If you can draw a simple topology diagram it will help. If you care looking for HSRP config, the following page should help
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
-Prashanth
96
