Need to connect TTY lines across WAN
How do I connect 2 tty lines across a WAN ?
The scenario is that a Paging Switch connects to a Cisco 3660 on TTY line 97. This Switch needs to talk to another Paging Switch connected to a similar Cisco 3660 on line 166. It's like a Master/Slave config. The end modules on the Paging switch have no IP routing capability.
Any info on how to proceed is appreciated.
Thx
George
1 REPLY
Re: Need to connect TTY lines across WAN
You need to tunnel async data over ip. For that you can use "autocommand telnet " feature under the line config of 3660.
Following link will explain that in details about the config etc..
http://www.cisco.com/warp/public/700/14.shtml
103
