Need to NAT to certain destination and not others
I need to NAT addresses inside on the ethernet LAN and outbound on the serial destined for a specific network and not NAT all the rest. I have a pool set up and an extended ACL with the source and destination networks of the network I want to NAT to defined. When I ping a loopback in the network sourced from the routers ethernet it works like I expect. It doesn't NAT because it's not in the ACL. But once I ping an address using the NAT extended ACL which also works like I expect, then all traffic appears to be NAT'd from that point on. Even the ping to the loopback that worked previously. I can see this in the NAT stat's. Anyone have any idea? It's a 1721 router running 12.2.8T.
VIP Purple
Re: Need to NAT to certain destination and not others
can you post your configuration, as well as the output of the command:
show ip nat translations
Georg
Here's the NAT piece of the config.
ip nat pool localsite 10.114.7.2 10.114.7.254 netmask 255.255.255.0
ip nat inside source list ToDenBosch pool localsite
ip access-list extended ToDenBosch
permit ip 192.168.7.0 0.0.0.255 10.65.16.0 0.0.0.255
interface FastEthernet0
ip address 192.168.7.68 255.255.255.0
ip address 10.114.7.1 255.255.255.0 sec
ip nat inside
interface Serial0.1
ip nat outside
Anonymous
N/A
Hi Bleddy,
I am having exactly similar problem with the NAT issue you had. Have your problem resolved yet? If yes, is it possible to share your solution with me.
Many thanks.
best regards,
Chee
91
