Need to simulate fractional T-1 for test lab.
Hi All,
How can I set up a pair of routers to simulate a fractional T-1? I have a pair of 2500s with a back to back serial cable, and I want to vary the actual link speed from full T-1 down to 128k to test some servers that will be on each end.
Is there any easy way to do this?
Thanks, Randy
Re: Need to simulate fractional T-1 for test lab.
Randy,
You can vary the clock rate on the physical DCE side of your back-to-back cable. Is that enough for you? I forget the speeds a 2500 will do, but you can verify this by typing "clock rate ?" to see the different speeds your 2500 will do.//CM
On the DCE side, (below is a 2500)
tweety(config-if)#clock rate ?
Speed (bits per second)
<300-4000000> Choose clockrate from list above
so to run 128K, it would be clock rate 128000
Then the DTE side would automatically clock off of the DCE side.
90
