NEED URGENT HELP ON MY CISCO 2600 ROUTER.
This machine is giving me hard time. The problem with it is that it keeps on rebooting. I have tried to even load another IOS. But it is not working out. It is bringing this output......========= Dump bp = 2C66478 ======================
2C66378: 0 0 0 0 0 0 0
2C66398: 0 0 0 0 0 0 0
2C663B8: 0 0 0 0 0 0 0
2C663D8: 0 0 0 0 0 0 0
2C663F8: 0 0 0 0 0 0 0 FD0110D
F
2C66418: AB1234CD FFFFFFFE 0 0 800261A4 2C66478 2C183EC 8000001
C
2C66438: 1 175C7D59 70600180 DCBE0B00 C164 0 100 2C664A
2C66458: 2C668E0 0 0 0 0 0 0 FD0110D
F
2C66478: AB1234CD FFFFFFFE 0 0 800261C8 2C668B8 2C6642C 8000020
C
2C66498: 1 A35C1E12 15A 8000F9F4 2C67160 0 15A 8000F9F
2C664B8: 2C677E0 0 15A 8000F9F4 2C67E60 0 15A 8000F9F
2C664D8: 2C684E0 0 40 8000F9F4 2C68B60 0 40 8000F9F
2C664F8: 2C691E0 0 0 8000F9F4 2B657E0 0 0 8000F9F
2C66518: 2B65160 0 0 8000F9F4 2B64AE0 0 0 8000F9F
2C66538: 2B64460 0 0 8000F9F4 2B63DE0 0 0 8000F9F
2C66558: 2B63760 0 0 8000F9F4 2B630E0 0 0 8000F9F
========= Dump bp->next = 2C668B8 ======================
2C667B8: 2B73E20 0 0 8000F9F4 2B737A0 0 0 8000F9F
2C667D8: 2B73120 0 0 8000F9F4 2B72AA0 0 0 8000F9F
2C667F8: 2B72420 0 0 8000F9F4 2B71DA0 0 0 8000F9F
2C66818: 2B71720 0 0 8000F9F4 2B710A0 0 0 8000F9F
2C66838: 2B70A20 0 0 8000F9F4 2B703A0 0 0 8000F9F
2C66858: 2B6FD20 0 0 8000F9F4 2B6F6A0 0 0 8000F9F
2C66878: 2B6F020 0 0 8000F9F4 2B6E9A0 0 0 8000F9F
2C66898: 2B6E320 0 0 0 0 0 0 FD0110D
F
2C668B8: AB1234CD FFFFFFFE 0 3000000 80026214 2C670F8 0 300040
C
2C668D8: 1 8DB14C70 0 8300FECE 2B050C2 0 0 8300FEC
E
2C668F8: 2B057A2 0 0 300FECE 2B05E82 0 0 300FFC
2C66918: 2B01D8A 0 0 8300FFC4 2B01ECA 0 0 8300FEC
9
2C66938: 2CD38C2 0 0 300FFC4 2CCF22A 0 0 300FFC
2C66958: 2CCF4AA 0 0 8300FFC4 2CCF72A 0 0 8300FFC
2C66978: 2CCF9AA 0 0 0 0 0 0
2C66998: 0 0 0 0 0 0 0
========== Dump bp->previous = 2C6642C =====================
2C6632C: 0 0 0 0 0 0 0
2C6634C: 0 0 0 0 0 0 0
2C6636C: 0 0 0 0 0 0 0
2C6638C: 0 0 0 0 0 0 0
2C663AC: 0 0 0 0 0 0 0
2C663CC: 0 0 0 0 0 0 0
2C663EC: 0 0 0 0 0 0 0
Then it says (Software forced reload.) Pliz help.
Silver
Re: NEED URGENT HELP ON MY CISCO 2600 ROUTER.
This does not look good. Boot into rommon. Use the "verify flash:c2600*.bin" command to check the integrity of the image.
If this issue impacts your production environment contact TAC for a quick resolution.
--Leon
Blue
turn off router.
reseat flash and DRAM if you can within the router. assure they are fine.
verify the IOS version(s) you're loading are appropriate for your memory.
load lower version IOS if required.
109
