Netbios/Domain Problems
I have multiple locations connected to a district office that need to have computers on the WAN connect to the domain. This previously worked until we acquired new routers. I have gone through the configurations and can't find the problem, however I am fairly new to routers. The remote workstations are configured for netbios over tcpip. The router config for the central office and one remote location are below, and help would be appreciated.
Using 3610 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname COHOST
enable secret 5 $1$INbH$YRTczMDDaNUvcTei063l1.
ip subnet-zero
ip domain-name vnet.net
ip name-server 166.82.1.3
ip name-server 166.82.1.8
interface FastEthernet0/0
description ToLan
ip address 10.1.1.3 255.255.0.0
ip nat outside
duplex auto
speed auto
interface Serial0/0
description To BellSouth FR CKTID 20.QGXX.505355
no ip address
ip directed-broadcast
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/0.100 point-to-point
description To Casar Elementary CKTID 20.QRXX.502033
ip address 10.255.255.1 255.255.255.252
ip nat inside
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 5
frame-relay interface-dlci 100
interface Serial0/0.101 point-to-point
description To Union Elementary CKTID 20.QRXX.502032
ip address 10.255.255.5 255.255.255.252
ip nat inside
frame-relay interface-dlci 101
interface Serial0/0.102 point-to-point
description PVC to BHS
ip address 10.152.1.2 255.255.0.0
ip nat inside
frame-relay interface-dlci 102
interface Serial0/0.103 point-to-point
description PVC to CHS
ip address 10.255.255.10 255.255.255.252
ip nat inside
frame-relay interface-dlci 103
interface Serial0/0.104 point-to-point
description PVC to TS3
ip address 10.150.1.2 255.255.0.0
ip nat inside
frame-relay interface-dlci 104
interface Serial0/0.105 point-to-point
description PVC to SES
ip address 10.151.1.2 255.255.0.0
ip nat inside
frame-relay interface-dlci 105
interface Serial0/1
description To Bellsouth FR CKTID 20.QGXX.505414
no ip address
no ip mroute-cache
interface Serial0/1.100 point-to-point
description PVC to CHS Only 2nd T
ip address 10.153.1.2 255.255.0.0
ip nat inside
interface Serial0/1.101 point-to-point
description PVC to BHS 2nd T1
ip address 10.154.1.2 255.255.0.0
ip nat inside
router eigrp 100
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.0.10
ip route 10.8.0.0 255.255.0.0 10.1.10.1
ip route 10.12.0.0 255.255.0.0 10.152.1.1
ip route 10.16.0.0 255.255.0.0 10.152.1.1
ip route 10.20.0.0 255.255.0.0 10.255.255.2
ip route 10.24.0.0 255.255.0.0 10.255.255.9
ip route 10.24.0.0 255.255.0.0 10.153.1.1
ip route 10.28.0.0 255.255.0.0 10.255.255.9
ip route 10.36.0.0 255.255.0.0 10.1.10.5
ip route 10.40.0.0 255.255.0.0 10.152.1.1
ip route 10.64.0.0 255.255.0.0 10.151.1.1
ip route 10.68.0.0 255.255.0.0 10.150.1.1
ip route 10.70.0.0 255.255.0.0 10.255.255.6
ip route 10.76.0.0 255.255.0.0 10.1.10.4
ip route 10.101.0.0 255.255.0.0 10.255.255.9
no ip http server
ip pim bidir-enable
access-list 1 permit 10.151.0.0 0.0.255.255
access-list 1 permit 10.150.0.0 0.0.255.255
access-list 1 permit 10.152.0.0 0.0.255.255
snmp-server community public RO
snmp-server chassis-id COHOST
Remote Site
Using 1903 out of 29688 bytes
version 12.2
hostname CHS2HOST
enable secret 5 $1$X3.w$3YhFiXuIPIVtelcHPcl5y1
enable password cisco
username ccssrtr privilege 15 password 0 ccssadmin
ip subnet-zero
description 2LAN
ip address 10.24.1.1 255.255.0.0
ip policy route-map CHS
duplex auto
speed auto
interface Serial0/0
description To Bellsouth FR CKTID 20.QRXX.505393
no ip address
no ip mroute-cache
fair-queue
description TO COHOST
ip address 10.255.255.9 255.255.255.252
interface Serial0/1
description TO COHOST Second T1
no ip address
no ip mroute-cache
description PVC to 2nd T1
ip address 10.153.1.1 255.255.0.0
router eigrp 100
network 10.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.255.255.10
ip route 10.28.0.0 255.255.0.0 10.24.1.2
ip route 10.101.0.0 255.255.0.0 10.24.1.3
no ip http server
no ip pim bidir-enable
access-list 1 permit 10.24.0.0 0.0.255.255
access-list 2 permit 10.28.0.0 0.0.255.255
access-list 2 permit 10.101.0.0 0.0.255.255
route-map CHS permit 1
match ip address 1
set ip next-hop 10.153.1.2
1 ACCEPTED SOLUTION
Bronze
Re: Netbios/Domain Problems
One suggestion. If you are using DHCP and WINS servers at the central site, which is usual with Netbios over TCP, then you would require a helper address configured on the remote LAN interface pointing to the server address in order to forward broadcast traffic.
eg
ip helper-addresss
Bronze
eg
ip helper-addresss
Rob, need to be careful sharing so much info for your question. Get rid of things like passwords, even encrypted. Especially when your info is about a public domain connection you have.
Cheers
Ditto: HEY MODERATOR!!! (Sorry, had to yell to get your attention)Can you pull his post, let him edit it and resubmit the question? We don't need stuff like this hanging out there for the world to see
94
