Anonymous
N/A
Netconfig java problem
Hello, im trying to set-up a netconfig Job, i am defining a ad hoc job a simple access-list amendment i cna define the job and apply it to a templete but when i click next i get lots of Java errors, i have only come across this in Netconfig nothing else:
The message reads Unable to retrieve message from catalog for message ID 816:
exception encountered :
Java.lang.exception: message id 816 not found
then lots of java libraries listed where the file was not found.
any ideas
I have tried from diffrent clients and rebooting the server
thanks
Colin
Blue
Re: Netconfig java problem
Same problem if you use both Netscape/IE ?. Have you tried clearing your browser/plug-in cache?
Colin,
This message comes when you upgrade RME 3.3 + IDU combination to RME 3.4. Correct me if i'm wrong.
Installing latest IDU that's IDU 3.0 should solve this issue. You can download it from Software Center at CCO site.
amol
Anonymous
N/A
I had already installed this patch but i have installed it again and
netconfig is working now.
Many thanks
Colin
91
