Community Member
Netflow export problem
I have a cisco router cisco 2611 (MPC860) with IOS Version 12.2(8)T5.
I configured:
ip flow-cache timeout inactive 10
ip flow-cache timeout active 10
ip cef
interface Ethernet0/1
ip address 10.161.1.2 255.255.0.0
ip accounting output-packets
ip route-cache flow
ip policy route-map internet
half-duplex
bridge-group 1
interface Serial0/1
bandwidth 2000
no ip address
encapsulation frame-relay
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
frame-relay traffic-shaping
ip flow-export source Ethernet0/1
ip flow-export version 5
ip flow-export destination 10.150.0.102 9995
But, I am not receiving the flow on my Unix-Solaris (10.150.0.102) server.
when I execute sh ip flow export:
Flow export is enabled
Exporting flows to 10.150.0.102 (9995)
Exporting using source interface Ethernet0/1
Version 5 flow records
7994835 flows exported in 266495 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
What it could be happening ? Please, I need help.
1 REPLY
Community Member
Re: Netflow export problem
check your policy map config on your ethernet interface. It may not be classifying and matching packets correctly
281
