Community Member
Network access problem
Hi all,
My problem is the next.
I would like to connect this two networks:
Net 10.2.1.0< --cisco 801(197.10.1.1) <-----ISDN <----cisco 700 (197.10.1.2) <-----> 10.3.1.0
I have connected the two cisco routers, cisco 700 as remote site and cisco 801 as central site, with an ISDN line.Now the connection between the routers is OK. But I can not do telnet or FTP from any PC of any network and I don't know what is wrong.
I will be very gratefull if anyone can help me.
Best regards,
Susana
Re: Network access problem
Susana,
Without the configs, we don't know either.
Community Member
Hereinafter I have listed both configurations.
CISCO 801
_________
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname DFBUCIS2
enable password
username itwbel password
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0
description connected to Burgos
ip address 10.2.1.250 255.255.255.0
interface BRI0
description connected to itwbel
no ip address
encapsulation ppp
dialer rotary-group 1
no cdp enable
interface Dialer1
ip address 197.10.1.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name itwbel broadcast
dialer map ip 197.10.1.2 name itwbel broadcast
dialer-group 1
snapshot server 15 dialer
no cdp enable
ppp authentication chap
router rip
version 2
passive-interface Ethernet0
network 197.10.1.0
no auto-summary
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
dialer-list 1 protocol ip permit
snmp-server engineID local 000000090200000217661DCE
snmp-server community public RO
snmp-server location Burgos
line con 0
exec-timeout 0 0
password
login
transport input none
stopbits 1
line vty 0 4
exec-timeout 0 0
password
login
no rcapi server
end
CISCO 700
_________
CD
SET SCREENLENGTH 20
SET COUNTRYGROUP 4
SET LAN MODE ANY
SET WAN MODE ONLY
SET AGE 300
SET MULTIDESTINATION ON
SET SWITCH NET3
SET ALAWVOICE ON
SET INTERNALTONES NONE
SET 1 DELAY 30
SET 2 DELAY 30
SET BRIDGING OFF
SET LEARN ON
SET PASSTHRU OFF
SET SPEED AUTO
SET PLAN NORMAL
SET 1 AUTO ON
SET 2 AUTO ON
SET 1 NUMBER
SET 2 NUMBER
SET 1 BACKUPNUMBER
SET 2 BACKUPNUMBER
SET 1 RINGBACK
SET 2 RINGBACK
SET 1 CLIVALIDATENUMBER
SET 2 CLIVALIDATENUMBER
SET CLICALLBACK OFF
SET CLIAUTHENTICATION OFF
SET SYSTEMNAME itwbel
LOG CALLS TIME
LOG ERRORS
SET UNICASTFILTER OFF
DEMAND 1 THRESHOLD 0
DEMAND 2 THRESHOLD 48
DEMAND 1 DURATION 1
DEMAND 2 DURATION 1
DEMAND 1 SOURCE LAN
DEMAND 2 SOURCE BOTH
TIMEOUT 1 THRESHOLD 0
TIMEOUT 2 THRESHOLD 48
TIMEOUT 1 DURATION 0
TIMEOUT 2 DURATION 0
TIMEOUT 1 SOURCE LAN
TIMEOUT 2 SOURCE BOTH
SET AOCDTIMEOUT OFF
SET REMOTEACCESS PROTECTED
SET LOCALACCESS ON
SET CLICKSTART ON
SET LOGOUT 20
SET CALLERID OFF
SET PPP AUTHENTICATION IN CHAP
SET PPP CHAPREFUSE NONE
SET PPP AUTHENTICATION OUT NONE
SET PPP AUTHENTICATION ACCEPT EITHER
SET PPP TAS CLIENT 0.0.0.0
SET PPP TAS CHAPSECRET LOCAL ON
SET PPP SECRET CLIENT ENCRYPTED
SET PPP CALLBACK REQUEST OFF
SET PPP CALLBACK REPLY OFF
SET PPP NEGOTIATION INTEGRITY 10
SET PPP NEGOTIATION COUNT 10
SET PPP NEGOTIATION RETRY 3000
SET PPP TERMREQ COUNT 2
SET PPP MULTILINK OFF
SET PPP MULTILINK PPPHEADER ON
SET COMPRESSION OFF
SET PPP BACP ON
SET PPP ADDRESS NEGOTIATION LOCAL OFF
SET PPP IP NETMASK LOCAL OFF
SET IP PAT UDPTIMEOUT 5
SET IP PAT TCPTIMEOUT 30
SET IP RIP TIME 30
SET CALLDURATION 0
SET SNMP CONTACT ""
SET SNMP LOCATION ""
SET SNMP TRAP COLDSTART OFF
SET SNMP TRAP WARMSTART OFF
SET SNMP TRAP LINKDOWN OFF
SET SNMP TRAP LINKUP OFF
SET SNMP TRAP AUTHENTICATIONFAIL OFF
SET DHCP OFF
SET DHCP DOMAIN
SET DHCP NETBIOS_SCOPE
SET CALLTIME VOICE INCOMING OFF
SET CALLTIME VOICE OUTGOING OFF
SET CALLTIME DATA INCOMING OFF
SET CALLTIME DATA OUTGOING OFF
SET USER LAN
SET BRIDGING OFF
SET IP ROUTING ON
SET IP ADDRESS 10.3.1.254
SET IP NETMASK 255.255.255.0
SET IP FRAMING ETHERNET_II
SET IP PROPAGATE ON
SET IP COST 1
SET IP RIP RECEIVE V1
SET IP RIP UPDATE OFF
SET IP RIP VERSION 2
SET USER Internal
SET IP ROUTING ON
SET IP ADDRESS 0.0.0.0
SET IP NETMASK 0.0.0.0
SET IP RIP VERSION 1
SET USER Standard
SET PROFILE ID 000000000000
SET PROFILE POWERUP ACTIVATE
SET PROFILE DISCONNECT KEEP
SET IP ROUTING ON
SET IP FRAMING NONE
SET USER DFBUCIS2
SET BRIDGING OFF
SET 1 NUMBER
SET 2 NUMBER
TIMEOUT 1 DURATION 60
TIMEOUT 2 DURATION 60
SET PPP AUTHENTICATION OUT CHAP
SET PPP CLIENTNAME itwbel
SET PPP PASSWORD CLIENT ENCRYPTED
SET PPP PASSWORD HOST ENCRYPTED
SET PPP SECRET HOST ENCRYPTED
SET IP ROUTING ON
SET IP ADDRESS 197.10.1.2
SET IP NETMASK 255.255.255.252
SET IP FRAMING NONE
SET IP PROPAGATE OFF
SET IP COST 1
SET IP RIP RECEIVE V2
SET IP ROUTE DEST 10.2.1.0/24 GATEWAY 197.10.1.1 PROPAGATE OFF COST 1
SET IP RIP SNAPSHOT CLIENT ACTIVE 15 QUIET 360 UPDATE ON
CD
LOGOUT
Susana
Community Member
Hi Susana,
Have you tried to introduce in the configuration the command:
Community Member
Hi Gorge,
Could you be so kind as to write the command again? In the screen I only see " Have you tried to introduce in the configuration the command" but I don't see the command.
Susana
Community Member
Hi Susana, sorr a lot,
the command line is: line vty 0 4 that command permit access to the router through telnet.
P.D: sorry if my english is a bit bad but i´m triyiny to improve it ;-))
Regards.
There are a few odd thing in 801 config. Please try the following:
no ip route 0.0.0.0 0.0.0.0 eth0 I do not see the need for this route.
add the following route:
ip route 10.3.1.0 255.255.255.0 197.10.1.2
As far as I can see this will do the job but I would also advise you to remove the RIP routing process from both boxes. Otherwise you run the risk of the ISDN line being connected 24 hours per day.
On the 801:
no router rip
Remove the dialer map xx broadcast line and replace it with the same mapping, without the broadcast statement. To achieve this use the no dialer map command using your old line and then reenter the same line without the broadcast keyword as follows:
int di1
no dialer map xxxx broadcast
dialer map xxxx
On the 700 series it looks to me as if you have used config-maker. You should run this again to remove the rip routing The required static route is already there.
Goodluck!
Community Member
At the end I have solved the problem betwwen both routers.The problem was the route into the cisco 801 as lgijssel wrote.
Many thanks for all your help.
110
