Network Admission Control(NAC). Dynamically check for machine security requ
Hi All,
Please suggest how to Accomplish the below scenario..
1) Enable 802.1x on Cisco switches - Network Admission Control(NAC). Dynamically check for machine security requirments and based on user ID put them in appropriate VLAN and apply access policies.
2)If a workstation does not comply with security requirements(Not having the correct patches, AV software, Firewall etc) the machine would be automatically moved to Remediation ( a separate VLAN for security reason) VLAN.
1 REPLY
Re: Network Admission Control(NAC). Dynamically check for machin
Hi Prateesh,
You are looking for NAC feature. For this you basically need 3 major parts. Policy server, NAC aware devices and end stations with proper software installed.
You need a policy server on you network which could be AAA server at the back end and router with NAC aware IOS feature set. on the end station you need CSA ( Cisco Security agent ). With the conmination of these three componenets you will be able to achieve the end-point security.
Please go through the link below for more info :
http://www.cisco.com/en/US/netsol/ns617/netqa0900aecd800fdd6f.html
HTH, Please rate if it does.
-amit singh
91
