Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
network infrastructure planning advice
I need to set up a new network: "Network A". It needs to have a t1 to "Network B", a backup t1 to "Network B", and a t1 to "Network C". In the near term future there will be a T1 to "Network C" and a T1 to "Network D".
What is a good router configuration for "Network A"? How many routers? What models? What T1s to what routers?
thanks
1 REPLY
Silver
Re: network infrastructure planning advice
In addition to ur stated requirements, I would also wish to know what type of connections(Long time, short time) and what is going to be the distance b/w ur Network A and other networks?
Here r the two main WAN connection :
1.For short Distances and long connection times - Leased line is far better.
2.If u want to use shared bandwidth and more efficient packet switching and for Long distances(Long connection times) - frame-relay is good.
Both these technologies provide more than T1 (1.544 mbps) speed connectivity.
Since, u need a T1 backup, ISDN PRI provides this T1 speed connectivity and so u can use it as backup line.It is a circuit switched n/w.
94
