04-17-2006 03:58 AM - edited 03-03-2019 02:50 AM
can you tell what is the part number of 10/100 Mbps network interface module which will suit on 1751 slot, because by defauly fastherethernet is in-built in that module, i wanted to have one more additional interface.
04-17-2006 04:27 AM
The WIC-1ENET will add 1 addtional 10Mbps ethernet port to your router.
You can also get the WIC-4ESW a 4 port 10/100 ethernet switch module for the 1751.
Hope this helps.
Steve
04-17-2006 04:41 AM
thanks for the reply, can you tell me the site where i can get these info?
04-17-2006 05:43 AM
The WIC 1-ENET: http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088714.html
For the WIC-4ESW:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801c749d.html
Hope this helps.
Steve
