network issue
Static routes are added.both network pcs are able to access oracle server.
Internet facility is available only in router A network , router B network pcs are not able to browse internet. mask has changed to 255.255.0.0 and checked, also add route has been checked in pc. both case is not working.
Re: network issue
Is the BSNL modem is only modem or even a router?
If its a router then define a route in it
192.168.62.0/24 gateway 192.168.61.1
It will definately help
JD
PS:Pls rate the posts if they are helpful
Re: network issue
hi
there is no option for setting gateway....
only configurable is ethernet ip with subnet mask.
regards
Babu
Re: network issue
Have you depoloyed NAT anywhere in ur routers to go out to the internet ? or is it been taken care in the BSNL network ?
from the topology posted out here NAT happens somewhere in the BSNL Internet Gateway device which u have shown in the picture or may be in the BSNLs internal network.
If its done in the BSNL Internet Gateway device(modem) then u need to add the Location B(BLR) network too to get natted.
Also revert wht kinda device is being placed out there as Internet gatway device (modem) ?
If possible can you post the config of router A ?
regds
Re: network issue
Is there any options of enabling static route/ RIP in it
Can u tell the make and website of the modem?
JD
104
