01-29-2003 04:54 PM - edited 03-02-2019 04:39 AM
What should I do to find out more about our network and bandwith usage. We have a dedicated 2Mbps line with a cisco pix 509 and 3 2950 switches. I'm trying to find something than will track the bandwith usage and if possible warn us when someone is using all the bandwith (Internet radio etc....). Is there any software, not too expensive which would do this?
01-29-2003 11:49 PM
Hi Mapoitras,
Please do find the details below for bandwidth monitoring.
To monitor bandwidth you can use MRTG at
http://people.ee.ethz.ch/~oetiker/webtools/mrtg/
It can also help you to monitor other parameters if you work with the OID´s.
It works on Linux and even NT
To monitor services, conections and in fact everything, you can use NetSaint
at http://www.netsaint.org or
http://www.freshmeat.net . It works on Linux too.
Both are free
Please do clarify whether you would be looking at a Cisco Product.
Vatsan
01-30-2003 06:05 PM
Thanks for your help. I believe that www.netsaint.org is a *nix product only. Unfortunately, we are a small office and at this time we only have windows servers. So for now I need a windows compatible solution. I have found a windows version of MRTG and will try it for the next few days. We would be willing to purchase a solution for the right features.
thanks
MA
