Community Member
network management
How can I change Cisco Works login back to localhost ,instead of using authentication with either a radius or tacacs server,is there a perl script for it?
Blue
Re: network management
If you mean, user login authentication then login to CW2K->Server Configuration->Setup->Security->Select Login Module->CW2K Local and follow the screens
Community Member
I need to change from login authentication to TACACS,back to local log-in or restore from backup,if this is not possible.Seeing how I can't get to it with Tacacs down.
84
