Network Monitoring
Can any suggest me a good Network monitoring tool (Windows Platform) which should support ping testing for multiple IP addresses with email handlers, alarms.
Thanks in Advance.
Ganesh.I
Re: Network Monitoring
I have used Solar Winds. The network version. I have also used Compaq Insight Manager and HP Open View they are all good tools and each have specific vendor characteristics. For alot of monitoring and tools. I'd suggest "Solar Winds" first.
DTA
Ganesh
You may wish to look at What's Up Gold from Ipswitch.
wgk
I use Whatsup Gold, and use the SMTP feature to send email to pagers and cel-phones as well as desktops. Plus it logs events and has a simple color-coded status screen that indicates the state of each device (and it's services, such as http, ftp, or smtp) that you're monitoring.
Gordon
Blue
Have a look at: http://www.cisco.com/warp/public/cc/pd/wr2k/wrsnms/prodlit/snms_ds.htm. If you have a large network you can consider CW2000 bundle.
144
