Network Segments across wireless using two 2651
rbordeaux
I have a Voip network where two locations are going to be connected together over a 45Mb wireless connection, using two 2651 routers, to provide Qos. Both segments of this network are in the same ip subnet and will be trunking 3 vlans. Can someone give me any suggestions on configuration, Or point me to a site that would give me some information on this or a sample config.
lisa.hall
Level 2
Level 2
This is the link to the Voice Quality Support page. It has a lot of info on QoS over VoIP.
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Internetworking:Voice:QoS&viewall=true
I also found a doc on applying Qos on 802.1x. Not sure if it'll help.
http://www.cisco.com/warp/public/cc/pd/witc/ao350ap/prodlit/authp_an.htm
