Network traffic is saturated going outbound on my T1....
Peter010101
I am trying to find the source or sources of why my network traffic is saturated going outbound.
I set up a syslog server and have my pix sending it type 6 info alerts. I found some obvious problems and patched the pc's but that did not solve my problem.
I have also been running a sniffer (sniffer4.5 & ethereal) but I do not see anything obivous there either.
What should I be looking for specifically? Any one have any filters set up for ethereal that they would like to share?
Peter010101
Thanks for the advice everyone. I'll let you know how it goes.
I have two PIX to syslog logs that I looked thorough, But this time I used firewallanalyzer to do a report based on syslog data. Here is what I found:
12/4 12:33pm -2:18pm:
106011 No routing to arrival interface. event count 124426 38.45%
302013 Built TCP connection event count 84424 26.09%
106015 Deny TCP no connection established. event count 67932 20.99%
305011 TCP UDP ICMP Address Translation slot created. event count 33707 10.42%
302015 Built UDP connection event count 10883 3.36%
106023 Deny IP packet by access-list. event count 1884 0.58%
305005 Translate group not found. event count 192 0.06%
110001 No route.event count 54 0.02%
609001 event count 33 0.01%
305009 Address Translation slot created. event count 24 0.01%
Patched all the 106011 PC with latest security patched from Microsoft and the error event went away. I didn't know what to make of the 106015 events because they were from different PC's.
12/5 every 30 min starting at mindnight to 6 am:
106015 Deny TCP no connection established. event count 87481 75.67%
302013 Built TCP connection event count 11310 9.78%
302015 Built UDP connection event count 5048 4.37%
305011 TCP UDP ICMP Address Translation slot created. event count 3854 3.33%
305012 Teardown TCP UDP ICMP Address Translation slot. event count 3830 3.31%
106023 Deny IP packet by access-list. event count 3587 3.10%
305005 Translate group not found. event count 380 0.33%
110001 No route. event count 60 0.05%
302010 TCP connections in use. event count 21 0.02%
609002 Network state container for the host IP address connected to interface name is removed. event count 13 0.01%
A rdiculous amount of 106015 messages, 75% of my traffic, these come from about 10 different outside IP's.
