New 2948g - 2 problems
I am setting up a new 2948g switch. It came with a screwy config preloaded and I am having some problems setting everything straight.
1. I cannot ping my PC from this switch, but I can ping the default gateway. I can ping the switch from my PC. I am probably overlooking something simple. A PC that is hooked up to the switch shows a 100mb connection, but cannot ping anything.
2. What are the different settings that could come up under "method" when I type "sh ip int br". Currently it is set at NVRAM on the same switch.
I sure I am overlooking something
Thanks in advance,
Matt
  • Other Network Infrastructure Subjects
1 REPLY
Re: New 2948g - 2 problems
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
81
