Webcast-Catalyst9k
New Code (7.6.1) on Cat 4006 & Inline Power Problem now with AP 350
Upgraded code on 2 different 4006 switches w /Sup II's from 6.4.1 to 7.6.1. Problem now is on both switches my AP 350's port keep going down (ran fine before the upgrade) with the error - %SYS-3-PORT_NOPOWERAVAIL
I feel that the new code lowered the power output per port and it is too low for the AP 350.
Any thoughts on this?
1 ACCEPTED SOLUTION
Re: New Code (7.6.1) on Cat 4006 & Inline Power Problem now with
It's actually a bug in AP IOS.
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCea41998
Try disabling CDP as a workaround
Thanks that was the problem...
104
