New VLAN problem
I have problem in configuring new VLAN in 2950, when ever i established a more than one VLAN previous one is shutdown.
Only one VLAN is up at the time
Thank You
Re: New VLAN problem
Hi Mansoor,
Are you talking about the "interface vlan " i.e layer 3 SVI on the 2950. id yes, then as it is a layer 2 switch you can only enable one 1 interface vlan on this switch only to manage it. You can not have multiple Vlan SVI on this switch as it is on Layer 3 switches like 3550.
HTH, please rate if it does.
-amit singh
why you may ask, dont they both have multiple vlan active at the same time?????? well the answer is about $6000 USD. :)
-WM
Purple
The "interface vlan XX" is for managing the switch only and has nothing to do with routing , as far as actually creating "layer 2 " vlans you can create a minimum of 64 different vlans on this box .
102
