Newbie Needs help with frame-relay
I am new to this. I have 3 1601r with t1 wics. I have one hooke to a T1 for internet. The other 2 are to link a remote site back to to the main site across another T1 point to point. I got the internet working but cannot seem to get the other two talking. When I do sho frame-relay map I get Serial1.1 (down): point-to-point dlci, dlci 20(0x14,0x440), broadcast, IETF
status deleted
The following are the configs from those 2 routers:
! silverSouth.cfg - Cisco router configuration file
! Automatically created by Cisco ConfigMaker v2.6 Build 6
! Tuesday, February 24, 2004, 04:36:05 AM
! Hostname: silverSouth
! Model: 1601
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname silverSouth
enable password xxxx
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface Ethernet 0
no shutdown
description connected to EthernetLAN
ip address 10.166.53.251 255.255.255.0
keepalive 10
interface Serial 1
no shutdown
no description
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 remote-loopback full
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
no ip address
encapsulation frame-relay
frame-relay lmi-type cisco
interface Serial 1.1 point-to-point
no shutdown
description connected to Hickey
ip address 192.168.250.10 255.255.255.252
frame-relay interface-dlci 20 ietf
interface Serial 0
no description
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 192.168.250.0
no auto-summary
ip classless
no ip http server
snmp-server community public RO
no snmp-server location
no snmp-server contact
line console 0
exec-timeout 0 0
password silver
login
line vty 0 4
password silver
login
! The following commands are not recognized by Cisco ConfigMaker
! and are therefore appended here.
no service single-slot-reload-enable
end
NEXT ONE:
! Hickey.cfg - Cisco router configuration file
! Tuesday, February 24, 2004, 04:37:15 AM
! Hostname: Hickey
! Model: 1601
hostname Hickey
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
no shutdown
description connected to EthernetLAN_2
ip address 10.26.7.251 255.255.255.0
keepalive 10
interface Serial 1
no shutdown
no description
no ip address
no shutdown
description connected to silverSouth
ip address 192.168.250.9 255.255.255.252
interface Serial 0
no description
no ip address
shutdown
router rip
version 2
network 10.0.0.0
no auto-summary
ip classless
no ip http server
line console 0
exec-timeout 0 0
password silver
login
line vty 0 4
password silver
login
end
1 ACCEPTED SOLUTION
Re: Newbie Needs help with frame-relay
The DLCI's on each end of the circuit should not be the same since they are local. Check with your provider on what the DLCI should be on each end of the circuit. Is it possible that these circuits are not provisioned for frame-relay? Try using HDLC or PPP and see what happens. Assuming that a show int serial shows up,down.
Gold
Ran the results of your "show frame-relay map" command through Cisco's Output Interpreter Tool. Here's what I got back:
WARNING: Serial1.1 is DOWN, with a PVC state of DELETED.
Possible causes for a PVC state of DELETED:
1. There could be a cable, circuit, or CSU/DSU problem on one or more serial interfaces.
TRY THIS: Issue a 'show int' command for the main interface of which this is a subinterface.
If 'UP,DOWN', this is probably not a cable problem.
If 'DOWN,DOWN', this is probably a cable problem.
If 'DOWN,DOWN':
- Make sure that the cable is securely inserted into the fault serial interface.
- If you are using an external CSU/DSU, make sure that the cable is securely inserted and that the CSU/DSU is correctly configured to assert proper control signals (e.g. DCD, DSR, DTR).
- If you are using an integrated CSU/DSU, make sure the telco circuit is healthy (call your telco, do loopback testing, etc.).
- Move the connection to a different interface on this router to make sure the router interface is not faulty.
2. There could be a DLCI mismatch between you and the local frame-relay service provider. Either they are not using the DLCI that this router is using, or you have configured the wrong DLCI on your router.
TRY THIS: Check with your local frame-relay provider to insure your router's DLCI is the DLCI you should be using. If it is, make sure that the provider is using the same DLCI. If it is not, modify this router's DLCI accordingly.
3. Your connectivity is good, but your local frame-relay provider hasn't defined and/or activated your side of the PVC at all.
TRY THIS: Check with the local frame-relay provider to insure that the PVC is both defined correctly, and activated.
INFO: Your LMI type should always be set to the same value as your service provider. Your serial interface should never be looped.
INFO: On interfaces that are 'up', and 'defined, active', you may still have difficulty pinging the remote address. Do not try to ping the local address, as this does not provide any more information than is learned by pinging the remote address.
If this is a problem, there could be a problem with the service-provider's near and/or far end PVC definition, or with the remote end devices.
Make sure that you can ping the remote interface address. If you cannot, check the remote router's frame relay status, and then check with your frame-relay provider to insure the PVC is built correctly on both sides. If you can ping the remote interface address, but you cannot ping beyond it, there is likely a routing problem on either end. Make sure the next hop addresses are accurate in the routing tables.
Personally, for a new circuit I would suspect that your provider hasn't provisioned it yet, or if they have then they haven't activated it. Give them a call as the feedback above suggests, confirm the DLCI numbers and LMI-type, etc. Then ask them to "turn the line up" if it's not already up.
Link to the Output Interpreter Tool:
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
Hope this helps.
Called Qwest they said from their side all looks well. So I must have something wrong in my config.
Bronze
Are you sure the DLCI's are correct? Is it supposed to be 20 on both sides?
yes we are sure. The T1 for the internet was 16 and this one between the stores is 20.
Gold
DLCIs do not have to be the same at each end of the PVC since they are only locally significant; more often than not, they are NOT the same.
But they CAN be: I've been working with a customer who has about a dozen PVCs from Verizon. Each PVC has the same DLCI number assigned at both the local end and the remote end of the connection. The numbers are still only locally significant. But it's a useful coincidence that they are the same: when the customer uses the DLCI number to refer to a PVC, I know I know exactly which PVC he's talking about.
3111
