newbie question: how to get model info from cisco via snmp?
I want to judge which type cisco device is . Whether it is IOS or CATOS ? Is it version early 12.0 or later ?
Which OID can I use ?
thanks very much!
Blue
Re: newbie question: how to get model info from cisco via snmp?
Try using .1.3.6.1.2.1.1.1 (sysDescr)
Bronze
sysDescr or system will give you the info you need.
thanks for your reply.And I have another question,How can I know which mib the cisco device support? Like this ,some IOS device support CISCO-CONFIG-COPY,and another support OLD-CISCO-SYSTEM-MIB. When I code snmp program to copy cisco running-config to my tftp server,how did I know which OID I can use ? If I can get the device support CISCO-CONFIG-COPY,I can use 1.3.6.1.4.1.9.9.96.1.1.1.1,else I can use 1.3.6.1.4.1.9.2.1.55. .
thanks !
Bronze
thanks for your reply!
Are there any automatic methods to know devices MIB support ?I mean I want to code program to get devices MIB support infomation. I can't use mib toolkit and MIB locator.
So How can ?
thanks!
Anonymous
N/A
check if you receive a not empty snmp reply
2244
