newest Release for Cisco Catalyst WS-C3550-12T
piotrkrol
hi
which is the newest Release as a .tar file
for Cisco Catalyst WS-C3550-12T ?
at the moment I have Release 12.1.22-EA6 installed.
kind regards
piotr
pkhatri
Level 11
Level 11
Hi Piotr,
The latest non-deferred release you can get is:
12.2.25-SEC2
Pls follow the following link to choose the right feature set:
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=CAT3550&software_name=&release_name=12.2.25-SEC2&majorRel=12.2&state=:HW:RL&type=Early%20Deployment
(you will need appropriate CCO privileges).
Hope that helps ... pls rate the post if it does.
Paresh.
and which one is the last stable ?
I cannot open this link, because I don't have a user created.
Hi again,
This release has not been deferred and is still available for download. If there were any major issues with it, it would have been deferred. You might want to read the release notes for it, though, to see if any of the known bugs affect you.
As for downloading the image, you need to have a CCO login with appropriate privileges otherwise you will not be able to get it.
Hope that helps,
Paresh
