nGenius does not recognize Cat-2980G
I am running nGenious version 1.4 and attempting to add a Cat-2980G switch. I get the error message that the RTM does not recognize that device type. Does that mean the RTM can't monitor the Cat-2980G's?
Thanks.
1 REPLY
Blue
Re: nGenius does not recognize Cat-2980G
2980G is listed as supported 'Table 2: Cisco Catalyst Switches Supported by RTM': http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/fam_prod/netscout/rel_1_4/7814182.htm#xtocid14
Make sure that when you're adding this switch in RTM 1.4:
- Select the CAT2980G from the Select Switch Type pull-down and not use Automatic
- SNMP and RMON is enabled
- SP7 patch from CCO for RTM 1.4 is installed.
89
