- You don't need to add the NAM separately in RTM. You only need to add the switch in which the NAM(s) are installed with the correct device credentials, SNMP strings etc and RTM will automatically add the switch and learn the NAM(s).
- What kind of NAMs are these?. The old WS-X6380-NAM or the new WS-SVC-NAM-1/2 ?. The reason being that RTM 1.3 does not support the new WS-SVC-NAM-1/2. These are supported only in RTM 1.4 with the latest patch installed.
- Also make sure that you have installed the latest RTM 1.3 patch# 255 from CCO: http://www.cisco.com/cgi-bin/tablebuild.pl/rtm-13 which contains several important fixes.
- http://www.cisco.com/warp/public/477/RTM/rtm-nam.shtml is also something that you can look at for help.
