Webcast-Catalyst9k
nGenius RTM 1.4 Database problems
Has anyone else had any problems with there database getting corrupted. Our database gets hosed about every two weeks. I then have to reinitialize a new database losing all my settings and past data. This problem is on going for over a year and it's getting frustrating. I have all the lastest service packs installed for RTM. It's on a dedicated Windows 2k box and it only monitors 4 devices. I don't know what to do, if anyone has any ideas or has had a simliar problem I'd love to hear from you.
Blue
Re: nGenius RTM 1.4 Database problems
What exactly happens with the db?. Have you done CCO Bug Toolkit search to see if anything close shows up?
I'm unable to display historical stats in Link usage view. Sometimes for all devices but most of the time just my 6509s. Or I can only go back for two days if I go back any further it displays nothing. And the kicker is if I shutdown the services and restart them I will not be able to get back in. The error is "Make sure that nGenius services are running". Of course if I dump my old DB and create a new DB it lets me in. I have check ed bugs, I have had at least 3 TAC cases open and the fix is always just initalize a new database.
79
