12-11-2002 12:23 AM - edited 03-02-2019 03:31 AM
I have a new NM-1A-E3 Modul installed, HW-SW Matrix checked, correct ios downloaded, but Modul is not visible.
%PA-2-UNDEFPA: Undefined Port Adaptor type 427 in bay 1
Maybe ROM Version wrong ?
sh stack is ok.
Thanks Ruedi
Additional infos : sh vers, sh flash
Router#sh ver
IOS (tm) C2600 Software (C2600-JS-M), Version 11.3(5)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Wed 12-Aug-98 03:31 by ccai
Image text-base: 0x80008084, data-base: 0x80A31118
ROM: System Bootstrap, Version 11.3(2)XA3, PLATFORM SPECIFIC RELEASE SOFTWARE (f
c1)
Router uptime is 4 minutes
System restarted by power-on
System image file is "flash:c2600-js-mz.113-5.T.bin", booted via flash
cisco 2611 (MPC860) processor (revision 0x202) with 36864K/12288K bytes of memor
y.
Processor board ID JAB024905LP (980524050)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Router#
Router#sh flash:
System flash directory:
File Length Name/status
1 5808072 c2600-js-mz.113-5.T.bin
[5808136 bytes used, 10969080 available, 16777216 total]
Router#
Solved! Go to Solution.
12-11-2002 05:53 AM
Yes, you can find it on release notes, for example here:
12-11-2002 02:26 AM
According to the information on:
the minimun IOS required is 12.1(2)T
12-11-2002 02:29 AM
Hello, I have tried with 12.1(2)T as described in HW-SW Matrix. Same effect.
Regards Ruedi
12-11-2002 02:50 AM
You need an IP Plus version.
Andrea.
12-11-2002 05:18 AM
Hello Andrea,
That was it ! Now its ok.
Could I find this information (ip plus necessary) in IOS Rel. notes ?
For further cases...
Thanks for your help
Ruedi
12-11-2002 05:53 AM
