Please check your IOS version, I believe that the 12.1 & above should work and 12.2 version positively works since that is what is used in mine. Also may check what is amount of dram & flash. This message appears to be coming upon initial bootup, I once had to switch card slots on 2 cards(3620) just to make router bootup correctly. HTH Edward
