Community Member
NM-2CE1T1-PRI module not able to be detected on C3640 module
I have a problem here when i connect this module NM-2CE1T1-PRI to a C3640 Model(C3640-JK9S-M) , IOS ver 12.1,
I got this error:
Unsupported I/O Controller (type 926) in I/
O Bay. The I/O Controller network interfaces will be unavailable.
WHat is this due to ?
thanks!
1 ACCEPTED SOLUTION
Bronze
Re: NM-2CE1T1-PRI module not able to be detected on C3640 module
The Cisco E1/T1 ISDN PRI network modules are supported in the Cisco 2610-51XM, 2800, 2691, 3660, 3700, and 3800 routers. Refer http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html for more information.
Bronze
Community Member
You have been replied for this same query on 27th.
For more details on the module chk below link
Rahul
You need atleast 12.3 or 12.3T for this module to be supported on 3600 router.
HTH,
-amit singh
Community Member
What version of IOS you have ,I think the software you have not compatible with hardware
Community Member
Hi, I ran into this exact problem about 6 months ago. You will need the older NM, which is NM-2CT1-CSU, or the 1 port NM to work in the 3640..These are end of sale, so you will have to find one refurbished.
150
