Community Member
NMIDB loading problems in CiscoWorks
In Cisco Works 2000, NMIDB has been loaded at 10.0.059, but the comparison indicates that CCO is at version 10.0.058. I have heard that 10.0.060 is actually available, but I cannot get it through Cisco Works or find it in the software downloads on the Cisco site.
1 REPLY
Blue
Re: NMIDB loading problems in CiscoWorks
The latest nmidb is v1.0.061 which you can get from:
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi Select CV 5.3, 5.4 from the pull-down and select any device which will take you to the downlaod page and you'll see the files nmidb.1.0.061.zip and nmidb.1.0.061.readme listed.
129
